[Qgis-developer] morph delimited-text-provider to generic table-provider?
Raymond Nijssen r.nijssen at terglobo.nl
Mon Jul 11 00:16:57 PDT 2016
Hi Andreas,
I'd just like to see a way to create a new layer from any (attribute)
table in QGIS. So, even a point shapefile containing a wkt column with
polygons or a database table containing x and y field or an opened xls
sheet containing json somewhere.
My suggestion:
- To strip the geometry stuff from the CSV importer.
- Have a new tool to create a geometry layer from any QGIS table.
I think this would be easy to understand for users, although some would
need both tools to import a csv with geometry.
Regards,
Raymond
> Hi,
> I would welcome an "easier" way to open Point or WKT data from formats
> that do not store geometries natively, as you propose. Thanks for
> bringing it to the table, Raymond and Richard!
> My suggestion would be to enhance the existing OGR "Add vector layer"
> dialog with an option to choose columns to be used for geometry
> creation. This way we don't have to "misuse" the delimited text layer
> loader for other formats and the user could open the data all in one
> step, without the need for postprocessing. OGR VRT provides all we need
> to create geometries from columns - see http://www.gdal.org/drv_vrt.html
> The drawback is that it would work only for OGR formats, not for all the
> other databases. But I would assume that people using databases are
> skilled enough to be able to use QGIS virtual layers, views, etc. to
> build geometries from their databases.
> Greetings,
> Andreas
> On 2016-07-09 11:00, Richard Duivenvoorde wrote:
>> Hi Devs,
>> Raymond Nijssen had an (I think) intriguing idea:
>> QGIS can open different types of table-data: dbf, excel etc etc
>> But if the excel contains an x,y,wkt column, you have to save it to
>> csv/tsv first, to be able to use the delimited-text-provider to open it
>> as a layer.
>> His idea: can't we use the delimited-text-provider for all tables that
>> are open in QGIS immediately?
>> Had a look into the code
>> https://github.com/qgis/QGIS/blob/master/src/providers/delimitedtext/qgsdelimitedtextfile.cpp#L583
>> which 'just' looks like a QTextStream:
>> https://github.com/qgis/QGIS/blob/master/src/providers/delimitedtext/qgsdelimitedtextfile.h#L352
>> And according to this:
>> https://forum.qt.io/topic/63310/how-to-save-a-treeview-as-csv-file-in-qt
>> It is easy to create a textstream from QModel (in which we have the data
>> I think???)...
>> So Question:
>> - (to devs): would this indeed be doable/easy?
>> - (to UI's): should the Delimited Text File dialog be updated then (or
>> only with a 'open excisting table button'?
>> - should we rename the provider to 'table' provider.
>> Comments/Opinions?
>> Regards,
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
