[Qgis-developer] morph delimited-text-provider to generic table-provider?
Chris Crook ccrook at linz.govt.nz
Mon Jul 11 01:10:29 PDT 2016
Another thought .. why not use a plugin (which could emulate geometry component of DLT provider) to add geometry virtual fields to an existing layer?
Sounds really straightforward and would be available immediately and on older versions of QGIS.
Cheers
Chris
________________________________________
From: Qgis-developer [qgis-developer-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn [matthias at opengis.ch]
Sent: 11 July 2016 19:09
To: richard at duif.net; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] morph delimited-text-provider to generic table-provider?
On 07/10/2016 02:16 PM, Richard Duivenvoorde wrote:
> @mattias: mm, if I load a strict csv table (be it csv or excel),
> containing an x and y column, according to this blogpost:
> http://www.opengis.ch/2015/12/10/geometry-generator-symbology/
> I should be able to select a geometry generator in styles.. but with a
> table the styles is ... empty :-(
Fixing that should be possible.
Extending the CSV provider would result in rewriting a lot of driver
code which is already present in OGR.
I'd rather use one of the two methods
 * Geometry generators
 * Virtual layer
To build this functionality on top of any existing provider.
Matthias
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
