[Qgis-developer] SVG as attribute?
Raymond Nijssen r.nijssen at terglobo.nl
Fri Jul 15 01:51:01 PDT 2016
Hi Matthias,
A few weeks ago I asked a similar question here (titled: "custom
charts?"). You can store the filename and use a data defined svg image
in the styling tab:
with an SVG-marker the filename can be "data-defined", so you can for
instance use an expression like '/xxx/mymarker_' || id || '.svg'
QGIS cannot (yet) draw symbols using a piece of svg text in your table.
It would be great if it could though!
Good luck,
Raymond
On 15-07-16 10:38, Matthias Ludwig wrote:
> Hi,
> is it possible to store an plain svg in the attribute table for styling
> or is it just possible to save the path to the svg?
> Greetings
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
06 25 31 49 83
