[Qgis-developer] Release naming and path problems
Jürgen E. Fischer jef at norbit.de
Fri Jul 15 11:55:38 PDT 2016
On Fri, 15. Jul 2016 at 09:56:19 +0200, Jürgen E. Fischer wrote:
> QGIS itself doesn't have issues with it, does it?   I didn't notice anything
> when I test installed it (but w/o any plugins).
That's because I have short path support on the filesystem an so "QGIS Nødebo"
is turned into "QGISND~1" and problems don't appear.
> Anyway using the version number instead of the release name in the path
> shouldn't be a problem.   But that's "just" a packaging issue of the
> standalone.
The second version of the installer now uses the version number in the path.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160715/387b0c43/attachment.sig>
