[Qgis-developer] Update i18n/qgis_*.ts from source and not transifex
Werner Macho werner.macho at gmail.com
Mon Jul 18 06:20:42 PDT 2016
Hi!
Yes you can use the script like that if you do not want to change
anything (pulling from or pushing to) transifex.
QGIS (master)$ ./scripts/update_ts.sh update ./
kind regards
Werner
On 18/07/16 15:11, René-Luc Dhont wrote:
> Hi Duiv,
> I have found how to update i18n/qgis_*.ts without requesting transifex:
> Is it the right way ?
> Le 18/07/2016 14:57, Richard Duivenvoorde a écrit :
>> On 18-07-16 14:25, René-Luc Dhont wrote:
>>> Hi Devs,
>>> To finish a DB Manager feature, I'd like to update i18n/qgis_*.ts from
>>> source and not from transifex.
>>> I found some script to update i18n/qgis_*.ts files:
>>> * update_ts.sh
>>> * push_ts.sh
>>> * pull_ts.sh
>>> Which one can I use to update i18n/qgis_*.ts from source and not from
>>> transifex ?
>> Hi René-Luc,
>> if I'm correct the transifex resources are updated via a github commit
>> hook... So committing your change should make your new strings show up
>> on transifex too (within some time...)
>> Plz Juergen/Werner correct me if I'm wrong...
>> Regards,
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
