[Qgis-developer] Singleband pseudocolor GUI is too wide for styling panel
Mathieu Pellerin nirvn.asia at gmail.com
Thu Jul 28 01:35:34 PDT 2016
Anita,
Nyall is looking into this I believe.
M
On Thu, Jul 28, 2016 at 3:34 PM, Anita Graser <anitagraser at gmx.at> wrote:
> On Thu, Jul 28, 2016 at 10:01 AM, Mathieu Pellerin <nirvn.asia at gmail.com>
> wrote:
>> The problem with moving the [ edit ] button and the [x] invert checkbox
>> below the combo box is that it'd end up eating vertical space, which is as
>> precious and needed as horizontal spacing :)
> ​I'd rather scroll vertically than horizontally.
> Concerning vertical space: The Layer rendering and Resampling sections
> should be collapsible like the Load min/max values section. Actually, I
> think Layer rendering and Resampling are probably used less than Load
> min/max.
> Best wishes,
> Anita
>> On Thu, Jul 28, 2016 at 2:26 PM, Anita Graser <anitagraser at gmx.at> wrote:
>>> Hi Mathieu,
>>> On Thu, Jul 28, 2016 at 5:32 AM, Mathieu Pellerin <nirvn.asia at gmail.com>
>>> wrote:
>>>> Hey Anita,
>>>> Having worked on reducing the width of the rendering UIs in the last
>>>> dev cycle, I'm familiar with the issue raised here :)
>>>> Basically, the singleband pseudocolor renderer's minimum width is
>>>> determined (ATM) by the "Color [ramp]" row. More specifically, if you have
>>>> a color ramp with a long label, your combo box is going to eat a lot of
>>>> horizontal space. There's a lot that can be easily done to alleviate that
>>> ​Thank you for the insights! That makes sense. Maybe as a first simple
>>> step we could just rearrange the Edit and Invert buttons and move them
>>> below the color ramp combo box. The combo box itself could also have a
>>> maximum size which truncates longer ramp names.
>>> Should I open a ticket?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160728/e87c0455/attachment-0001.html>
