[Qgis-developer] (Yet again) SAGA support badly broken in QGIS
Paolo Cavallini cavallini at faunalia.it
Fri Jun 3 00:02:15 PDT 2016
Il 02/06/2016 15:09, Bas Couwenberg ha scritto:
> I notice a distinct lack of consideration for the SAGA LTR effort.
>From my side, I mentioned this as the second best option:
> * the best option would be for saga developers to adopt a more standard
> approach, e.g. avoid mixing up bugfixes (in point releases) and
> changes in the parameters (only in major releases), and keep backward
> compatibility for previous parameters in all life cycle of minor releases
> * if this is not feasible, the approach by Johan (maintaining a saga
> LTR) seems the best one, as it is a general solution, provided it is
> also followed by an appropriate versioning and dependency management for
> packages
All the best, and thanks to all for the interesting discussion.
Hopefully this will solve the iddue in a clean and stable way. IMHO this
would considerably improve the overall situation.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
