[Qgis-developer] QGIS on Mac with Qt5, PyQt5 and Py3
Larry Shaffer larrys at dakotacarto.com
Fri Jun 3 16:17:02 PDT 2016
Hi Nyall,
On Fri, Jun 3, 2016 at 10:58 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 4 Jun 2016 6:52 AM, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
> > Hi,
> > Just a quick note... Continuing work I started at the hackfest in
> Girona, I have successfully built and run QGIS on Mac off of Homebrew
> dependencies of pyqt, sip, qwt, qwtpolar, qscintilla2 and qca specifically
> configured for Qt 5 and Python 3.
> > http://drive.dakotacarto.com/qgis/qgis-qt5-pyqt5-py3.png
> > This means I am now capable of running installs of qgis2-ltr, qgis2 and
> qgis3 (when branched) off of the *same* /usr/local install of Homebrew.
> This also means, after some further work, we will be able to upgrade the
> Mac Travis CI setup for testing both Qt4/PyQt4/Py2 and Qt5/PyQt5/Py3, as is
> currently available for Linux.
> > While it is possible to do this using multiple isolated Homebrew
> installs, that requires almost all dependencies in the non-/usr/local
> directory to be compiled, instead of using the prebuilt binaries (aka
> 'bottles') available from Homebrew.
> > Fully bundled test apps are at least a month away.
> > I have a PR and more Homebrew editing to do (will post more to this
> thread later), but just wanted everyone to know it is at least compiling
> and launching on Mac!
> That's great news Larry - nice work!
> I'm curious: how does the test suite look on these qt5 Mac builds? What's
> failing?
See:
http://dash.orfeo-toolbox.org/buildSummary.php?buildid=231771
Not entirely sure I have the test environ set up correctly, but
  79% tests passed, 48 tests failed out of 231
isn't so bad as a starting point (I think...).
The following timed out:
PyQgsComposerHtml Failed  25m 30ms Completed (Timeout)
Most render test comparisons are close, excepting
qgis_composerlabeltest
http://dash.orfeo-toolbox.org/testDetails.php?test=41851057&build=231771
qgis_gradienttest
http://dash.orfeo-toolbox.org/testDetails.php?test=41851093&build=231771
qgis_composerpicturetest
http://dash.orfeo-toolbox.org/testDetails.php?test=41851065&build=231771
Also, about 50% of the Python test errors might be remedied with updating
to Py3 or some trivial module finding fixes.
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> Nyall
> > Regards,
> > Larry Shaffer
> > Dakota Cartography
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160604/07ba244f/attachment.html>
