[Qgis-developer] QGIS on Mac with Qt5, PyQt5 and Py3
Matthias Kuhn matthias at opengis.ch
Mon Jun 6 00:25:29 PDT 2016
Hi Larry,
Nice work, thanks a lot!
There is also the option -DPORT_PLUGINS=ON which is required to get the
processing tests to pass (and make a lot of the plugin functionality
compatible).
Is there any chance one could test the qgis-qt5 formulae?
Matthias
On 06/06/2016 01:31 AM, Larry Shaffer wrote:
> Hey Nyall,
> On Sat, Jun 4, 2016 at 4:24 PM, Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
>     I suspect you're building with deprecated code enabled. Can you
>     change the cmake option (I think it's "with_deprecated") and
>     rebuild/retest?
> Looks like it was already set: DISABLE_DEPRECATED:BOOL=ON.
> http://drive.dakotacarto.com/qgis/CMakeCache.txt
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
>     Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
