[Qgis-developer] QGIS Layer Search Plugin
Nathan Woodrow madmanwoo at gmail.com
Tue Jun 7 23:38:39 PDT 2016
I'm not really sure I see what moving to processing gives us in this case?
Why even make the user make the index files?
If it's integrated into core you can just generate the index on project
open like i do in Roam.  I just spin up a thread and make the index.  Just
have some place the user can config the search options but that can right
in the search bar itself.
Regards,
On Wed, Jun 8, 2016 at 4:35 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> On 06/08/2016 08:23 AM, Paolo Cavallini wrote:
> > Il 08/06/2016 08:20, Denis Rouzaud ha scritto:
> >> So...is this fair to ask someone to wait that long for a dev and then
> >> ask to modify its code to fit in? I have no answer, it's a real
> question.
> > Maybe cooperating on the same code base will make things much quicker
> > and more robust?
> > All the best, and thanks.
> Indeed asking to move the process to processing would a first step.
> Integrating this in QuickFinder shouldn't be too hard.
> I am available to discuss technical details, but I would need support
> for the processing part.
> Best wishes,
> Denis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160608/c63f5a40/attachment-0001.html>
