[Qgis-developer] Build issue on Ubuntu 16.04 xenial with release-2_14 : crssync target failed
Bas Couwenberg sebastic at xs4all.nl
Wed Jun 8 05:36:47 PDT 2016
On 2016-06-08 14:17, kimaidou wrote:
> It appears I had 2 gdal installed :
> one by qgis from qgis.org repository ( 1.11) which corresponds to
> /usr/lib/libgdal.so
> and one installed via apt-get install gdal-bin from repositories (2.1)
> which corresponds to : /usr/local/lib/libgdal.so
You got this the wrong way around, the package gdal is installed in
/usr/lib, you custom build in /usr/local/lib.
The /usr/local hierarchy is reserverd for the local administrator, /usr
for the system.
Kind Regards,
Bas
