[Qgis-developer] Geocoding plugin: a good case for merge
mederic.ribreux at medspx.fr mederic.ribreux at medspx.fr
Thu Jun 9 05:02:22 PDT 2016
Hello,
It could also be very interesting to have one or more  Processing module(s) for geocoding (natives QGIS "algorithms"). We could then chain this with other algorithms (find all objects of a layer intersecting a 500m buffer from the positions of the adresses in a list for example). Of course this module would be easier to write if we would have a native QGIS API for this...
Le 9 juin 2016 12:07:01 CEST, Richard Duivenvoorde <rdmailings at duif.net> a écrit :
>On 09-06-16 10:42, Paolo Cavallini wrote:
>>> I don't see any real opportunity to merge the plugins: some of them
>are
>>> > very specific to national geocoders, some other just ignore the
>TOS of
>>> > the webservices they use.
>> yes, this is clear to me. even if not much code is shared, from the
>user
>> point of view having a single menu, with a coherent interface where
>to
>> find all the services, would certainly be good.
>> for instance, the qgis2web was born in this way, and I believe it is
>a
>> good success.
>Thanks for bringing this up Paolo!
>I can add my 'pdokserviceplugin' to te list too :-)
>And MMQGIS plugin also has geocoder functionality
>Part of my plugin's interface is a 'search-bar' with which you do a
>quick geocode->zoomto action
>It is modelled to the 'search'-bar of Firefox: just fill with an addres
>and <enter>.
>Bottom part of:
>http://pix.toile-libre.org/upload/original/1465466009.png
>What about something like that:
>- we creating a gui-widget/toolbar for a geocoding search
>- we create a python api for it (actually: implement a buttonless
>plugin
>which registres the geocoder, and registres some slot/signals and does
>(part of) implementation)
>- by installing this plugin(s) you registre one or more geocoders, AND
>the plugin author actually implements the calling/retrieving/parsing of
>the results. We can maybe do some general standards in core (or via
>gdal): like OGC-OpenLS interface, or OSM-based ones or so
>- the core-geocoder gui then can look like the search bar in Firefox
>Upper part of:
>a little dropdown in which you can select WHICH geocoder you run by
>default
>- this core geocoder widget can then also implement a small 'multiple
>result' list...
>A side note:
>- some of the geocoders plugins Paolo lists, are 'one shot' geocoders:
>you sent one address and it returns one or two results. This is the
>geocoder I'm talking about
>- some of the geocoder plugins accept a csv/list, you have to select
>some columnnames and you sent the list to a service and you get a list
>back (with info about misses etcetc). This is much harder I think to
>implement in a general way? Would be cool though...
>pdokgeocoder and MMQGISplugin have these...
>Is this doable?
>Should we write a QEP for this?
>Regards,
>Richard
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Envoyé de mon appareil Android avec K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160609/6c140708/attachment.html>
