[Qgis-developer] SVG paths in print layout templates
Paolo Cavallini cavallini at faunalia.it
Mon Jun 13 03:30:01 PDT 2016
Il 13/06/2016 11:21, Frank Sokolic ha scritto:
> The same thing seems to happen with project files. If you create a
> project with an SVG (e.g. a north arrow) in Linux and then open the
> project in Windows, the SVG doesn't display in the map composer because
> the path is wrong. The SVG path seems to be dependent on the OS.
So it seems rather serious. Ticket opened:
http://hub.qgis.org/issues/15019
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
