[Qgis-developer] Segmentation fault when using layersRemoved SIGNAL.
    Germán Carrillo
    carrillo.german at gmail.com
    Mon Jun 13 13:53:51 PDT 2016
Hi All,
there seems to be an issue connecting the SIGNAL layersRemoved from
QgsMapLayerRegistry.
For example, if I save this script to a file, and run it from the Linux
terminal:
import unittest
from qgis.core import QgsApplication, QgsMapLayerRegistry
class SIGNALTest( unittest.TestCase ):
    def setUp( self ):
        app = QgsApplication([], True)
        QgsApplication.setPrefixPath("/usr", True)
        QgsApplication.initQgis()
        QgsMapLayerRegistry.instance().layersRemoved.connect(
self.myFunction )
    def myFunction( self, layerIds ):
        print "Called!"
    def test1( self ):
        self.assertEqual(1,1)
    def tearDown( self ):
        QgsApplication.exitQgis()
if __name__ == "__main__":
    unittest.main()
I get the following result:
Called!
Ran 1 test in 0.119s
OK
Segmentation fault
If, on the contrary, I comment out the line where the connection is set or
if I use other signals such as layerRemoved or layersAdded instead of
layersRemoved, I get:
Ran 1 test in 0.111s
OK
I'm using QGIS 2.14.2 on a GNU/Linux machine.
Can you confirm such problem? Do you have any clue about it?
Regards,
Germán
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
http://about.me/germancarrillo
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160613/4e005a5c/attachment.html>
