[Qgis-developer] The first column in the attribute table
Matthias Kuhn matthias at opengis.ch
Thu Jun 16 00:35:48 PDT 2016
Sure, you are right,
Sorry, the commit message was wrong but the code is ok.
Matthias
On 06/16/2016 09:28 AM, Neumann, Andreas wrote:
> Hi Matthias,
> Column header numbers? Aren't we discussing row header numbers?
> Andreas
> On 2016-06-16 09:25, Matthias Kuhn wrote:
>> Hi Andreas
>> It took me less time than it took me to write this email
>> https://github.com/qgis/QGIS/commit/9f704d6e92b922555bddb3a5a648edaac2aedf34
>> Matthias
>> On 06/16/2016 09:18 AM, Neumann, Andreas wrote:
>>> Hi Matthias,
>>> If there are no negative side effects - I'd like to see the same
>>> behaviour like in spreadsheets - an always ascending list, starting from
>>> 1 - regardless of the order of the rows.
>>> Would this be a lot of work to change this?
>>> Andreas
>>> On 2016-06-16 09:06, Matthias Kuhn wrote:
>>>> Hi Andreas,
>>>> I always thought that they are the feature ID. But not even that, often
>>>> they are "feature id - 1", but that's not guaranteed at all.
>>>> We could make it match the feature id. Or the current index in the table
>>>> like you propose.
>>>> Matthias
>>>> On 06/16/2016 08:56 AM, Neumann, Andreas wrote:
>>>>> Hi,
>>>>> I'd like to discuss an issue in the attribute table.
>>>>> There is this very first column (not stored in the provider) which
>>>>> lists
>>>>> the features as they appear in the provider (by default, if not
>>>>> re-ordered by the user). What are these values? Some internal ID not
>>>>> present in the data? Or some internal ID from the qt table widget?
>>>>> I am just wondering, because regarding this first column, QGIS behaves
>>>>> different from Spreadsheets.
>>>>> When you reorder the table in QGIS, this very first column becomes "out
>>>>> of order" - spreadsheets always display 1 to xxx - nicely ordered -
>>>>> regardless of the sort order. Could QGIS be aligned to the behaviour of
>>>>> spreadsheets or is there a particular reason not do so? I think, from a
>>>>> users perspective, because these numbers are not present in the data,
>>>>> that it would be more useful if they always stay ordered from 1 to xxx
>>>>> or 0 to xxx, regardless of sorting.
>>>>> Thank you for your feedback.
>>>>> Andreas
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> <mailto:Qgis-developer at lists.osgeo.org>
>>>>> <mailto:Qgis-developer at lists.osgeo.org>>
>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
