[Qgis-developer] The first column in the attribute table
Tom Chadwin
tom.chadwin at nnpa.org.uk
Fri Jun 17 14:11:47 PDT 2016
Matthias Kuhn-2 wrote
> In your case, it's dangerous to use the feature ids from one layer and
> assume that they match on another layer. You will have to find a common
> attribute (primary key) or (I guess you create one of the two layers in
> your script) copy the source feature id to the copied layer.
One layer is a copy of the other, but point taken. Will have to generate
another unique column on which I can depend.
Thanks
Tom
View this message in context: http://osgeo-org.1560.x6.nabble.com/The-first-column-in-the-attribute-table-tp5271947p5272261.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
