[Qgis-developer] MapInfo edition in QGIS
DelazJ delazj at gmail.com
Tue Jun 21 03:27:55 PDT 2016
Thanks for your answers. Even, I will keep in mind your safest answer.
But before I claim that everybody can somehow easily have access to mapinfo
files editing capabilities, any idea about MAC users?
2016-06-21 12:14 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le mardi 21 juin 2016 11:58:53, DelazJ a écrit :
> > Hi,
> > If I recall correctly, with GDAL2 in OSGeo4w, Windows users have now the
> > capabilities to edit Map Info files.
> > Is this available for other platforms, too? I often read "GDAL is in
> > Osgeo4w" and not "GDAL2 is in QGIS", reason why I'm asking....
> > I mean, if documenting map info files edit, should it be indicated that
> it
> > currently concerns only Windows users?
> That depends on the distribution and repository used. For example, on
> Ubuntu
> 16.04 if using ubuntugis-unstable PPA, you get QGIS 2.14.1 + GDAL 2.1.0.
> Safest answer: people have to check in the About dialog: if it indicates
> GDAL
> 2.0 or later, then they have .tab edition capabilities.
> > Thank you,
> > Harrissou
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160621/46c6bbbe/attachment.html>
