[Qgis-developer] No vector output with GRASS Processing
matteo matteo.ghetta at gmail.com
Tue Jun 21 09:02:58 PDT 2016
Hi all,
I ran random Grass 6 command with Processing but they always failed, and
that the final part Processing algorithm log:
GRASS_INFO_ERROR(21268,1): Vector map not found
GRASS_INFO_END(21268,1)
Closing monitors ...
Cleaning up temporary files ...
Batch job '/home/matteo/.qgis2//processing/grass_batch_job.sh' (defined
in GRASS_BATCH_JOB variable) was executed.
Goodbye from GRASS GIS
Converting outputs
Caricamento layer
The following layers were not correctly generated.
3D vector
You can check the log messages to find more information about the
execution of the algorithm
Some hints?
Should I open a ticket?
Thanks
Matteo
