[Qgis-developer] Interpretation of a 3 point CircularString with p0 == p2 (circle)
G. Allegri giohappy at gmail.com
Thu Jun 23 06:43:26 PDT 2016
Hi Even,
this difference catched my eye too. I think SQL MM (and consequently GDAL
and PostGIS) interpration is more logical, and I would suggest QGIS should
follow it too.
Giovanni
2016-06-23 15:32 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Hi,
> I just came into a difference how QGIS and GDAL interpret a CircularString
> made
> of a 3 points p0, p1, p2 where p0 == p2, which is a way of representing a
> full
> circle.
> GDAL interprets p1 as the symetrical point of p0 with respect to the center
> https://github.com/osgeo/gdal/blob/trunk/gdal/ogr/ogrcircularstring.cpp#L640
> that is p1 is on the perimeter of the circle, or said otherwise the center
> of
> the circle is the midpoint of [p0,p1].
> Whereas QGIS interprets p1 as the center of the circle (
> https://github.com/qgis/QGIS/blob/master/src/core/geometry/qgsgeometryutils.cpp#L359
> I'd think GDAL interpretation is the right one, since according to
> http://jtc1sc32.org/doc/N1101-1150/32N1107-WD13249-3--spatial.pdf (ISO
> SQL MM
> Part 3), paragraph 4.1.6 :
> (let's call this sentence S1)
> """ In the case where the segment is a circle, then the center is located
> at the midpoint of the line connecting the start point with the
> intermediate
> point. """
> But if you look a bit above in the paragraph, there's a sentence (call it
> S2)
> : """In the special case where a segment is a complete circle, that is, the
> start and end points are coincident, then the intermediate point shall be
> the
> midpoint of the segment. """, which looks confusing at first. I think this
> sentence must be interpreted considering distances along the curve, in
> which
> case the "midpoint of the segment" when doing a full walk along the circle
> from p0 back to p0 is the symetrical point of p0 with respect to the
> center.
> I think this interpretation is also more logical since, even in that
> particular case, p0,p1,p2 are all on the arc, like in the general case.
> I can also see that PostGIS (in
> https://github.com/postgis/postgis/blob/svn-
> trunk/liblwgeom/lwalgorithm.c#L252 ) has the same interpretation as GDAL
> I'd be happy to read opinions regarding this.
> Even
> (*) Can also be shown with :
> # SELECT
> ST_AsText(ST_Envelope(ST_CurveToLine(ST_GeomFromText('CIRCULARSTRING(-1 0,1
> 0,-1 0)'))));
>               st_astext
>  POLYGON((-1 -1,-1 1,1 1,1 -1,-1 -1))
> And http://postgis.net/docs/manual-2.2/using_postgis_dbmanagement.html
> says
> "The exception to this is for a closed circle, where the start and end
> points
> are the same. In this case the second point MUST be the center of the arc,
> ie
> the opposite side of the circle.", which is another way to rephrase S2.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160623/4db89caf/attachment.html>
