[Qgis-developer] [Qgis-user] R in QGIS on OSX using Kyngchaos build
William Kyngesburye woklist at kyngchaos.com
Sat Mar 5 08:42:37 PST 2016
Sorry I didn't reply to your earlier email.
I think it depends on how your scripts interact with R.  I have an R plugin for the GDAL framework.  I also have an R plugin for the GEOS framework, but that's for an old version of R.
You can run R scripts from the Processing plugin, but I don't know how that links R and QGIS data unless it's through GDAL.
There is also rpy2 for using R from python, supposed to be a simple instal with pip, but requires Xcode tools to compile.  I have a package for an old R version, but I could update it.
> On Mar 5, 2016, at 6:28 AM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> Hi guys
> I would like to use R scripts in  QGIS 2.12 from Kyngchaos and am unable to.
> I have installed the R package from r-project, and all  dependencies.
> When I run the R scripts that I have downloaded, I get the missing dependency problem.
> How do I go about rectifying it?
> Regards
> Pieter
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
