[Qgis-developer] Can not Run function when item selected in comboBox
    Luís Miguel Royo Pérez
    luis.miguel.royo at gmail.com
    Sun Mar  6 23:41:25 PST 2016
Dear list,
I'm writing a plugin, I want to change the content of a comboBox
(fields) depending of the content of another comboBox (layers).
My plugin is a dockwidget. I can populate the fields comboBox just
starting the plugin in the /def run(self):/ function, and it's working fine:
|layerNom =self.dockwidget.comboBoxErrores.currentText() #Getthe text
value of the comboBox forlyr
inQgsMapLayerRegistry.instance().mapLayers().values():#Get layers
iflyr.name()==str(layerNom):fields =lyr.pendingFields()#Get
Fielsfield_names =[field.name()forfield infields]#Field
Listself.dockwidget.comboCampos.addItems(field_names)#Add to the comboBox|
But when I try to update the content of the fields comboBox I really
don't know how to do it.
In my "pluginName_dockwidget.py" file, in the *init* function I have
created the connection with the function that will repopulate the
comboBox with the new content:
|self.comboBoxErrores.currentIndexChanged['QString'].connect(self.pueblaCampos)|
In the same file I have a function that get the value of the layer name
of the comboBox and emit it with the signal created previously:
|sennalComboIndex =pyqtSignal(str)...defpueblaCampos(self):layerName
=self.comboBoxErrores.currentText()self.sennalComboIndex.emit(layerName)|
In my main file, I have the rest of the function:
|defpueblaCampos(self,layerName):forlyr
inQgsMapLayerRegistry.instance().mapLayers().values():iflyr.name()==str(layerName):fields
=lyr.pendingFields()field_names =[field.name()forfield
infields]self.dockwidget.comboCampos.clear()self.dockwidget.comboCampos.addItems(field_names)|
When I change the slected item in the layers comboBox, nothing happens.
What Am I missing?
Ask for more detail info if you think it's needed. Thank you very much!!
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160307/8e208abe/attachment-0001.html>
