[Qgis-developer] QGIS has no future
Werner Macho werner.macho at gmail.com
Thu Mar 24 00:19:46 PDT 2016
Hi
Thanks for the explanation and describing exactly the way how I have
done it. I dont have a problem with it :)
Still it is not the "standard" way to install python modules inside
linux distributions - and that was all I wanted to say with it.
(beside that installing it with pip installs the modules in
/usr/local/lib whereas a distribution package installs them to /usr/lib)
Of course you can always assamble it somehow. But still (as a lot of
other modules are packaged for distributions) one would expect to have a
distribution package ready - which is not the case for debian stable
(only for testing and unstable)
So while it is easy for "us" installing it - some people might have
never used pip and expect everything coming installed with the QGIS
package. And for now I doubt the QGIS package installs the future module
with pip. That was all I wanted to point out.
kind regards
Werner
On 24/03/16 07:41, gene wrote:
> "There is no "python-future" in debian stable"
> I don't understand your problem. This is not the traditional way to install
> Python modules
> 1) simply go to the  Python Package Index (PyPI)
> <https://pypi.python.org/pypi>   and find  future
> <https://pypi.python.org/pypi/future>
> 2) the package documentation ( Python_future
> <http://python-future.org/index.html>  ) says that "python-future is the
> missing compatibility layer between Python 2 and Python 3. It allows you to
> use a single, clean Python 3.x-compatible codebase to support both Python 2
> and Python 3 with minimal overhead."
> 3) and you can find the  future.standard_library Interface
> <http://python-future.org/reference.html?highlight=standard_library#module-future.standard_library>
> 4) Now, how to install the package ? -> simply with  pip
> <https://pypi.python.org/pypi/pip/8.0.2>  , ( installation
> <http://python-future.org/quickstart.html#installation>  )
>     pip install future
> This is the modern procedure to install  Python modules for all the OS (and
> not apt-get install python-future or other commands)
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-has-no-future-tp5258029p5258129.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
