[Qgis-developer] Compile error with latest gdal
Werner Macho werner.macho at gmail.com
Wed May 11 04:47:10 PDT 2016
Hi Stefan,
Did you already try to start with a complete new build directory? And
in case of using ccache delete the compiler cache?
regards
Werner
On Wed, May 11, 2016 at 1:40 PM, Stefan Ziegler
<stefan.ziegler.de at gmail.com> wrote:
> Hi
> I get some errors when compiling QGIS master against GDAL master on Ubuntu
> 16.04:
> [ 64%] Built target postgresprovider
> [ 64%] Linking CXX executable ../../output/bin/crssync
> /usr/local/gdal_master/lib/libgdal.so: undefined reference to
> `IVFKDataBlock::GetFeatureCount()'
> collect2: error: ld returned 1 exit status
> src/crssync/CMakeFiles/crssync.dir/build.make:112: recipe for target
> 'output/bin/crssync' failed
> make[2]: *** [output/bin/crssync] Error 1
> CMakeFiles/Makefile2:1632: recipe for target
> 'src/crssync/CMakeFiles/crssync.dir/all' failed
> make[1]: *** [src/crssync/CMakeFiles/crssync.dir/all] Error 2
> Makefile:149: recipe for target 'all' failed
> make: *** [all] Error 2
> regards
> Stefan
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
