[Qgis-developer] BUG? strpos("area",'.') doesn't work
Mathieu Pellerin nirvn.asia at gmail.com
Mon Nov 7 04:12:48 PST 2016
I ll take care of this over the weekend. What should the regexp function be
called?
On Nov 7, 2016 7:10 PM, "Mathieu Pellerin" <nirvn.asia at gmail.com> wrote:
> You read my mind. Big +1 from me.
> On Nov 7, 2016 6:40 PM, "Matthias Kuhn" <matthias at opengis.ch> wrote:
>> I wonder if we should change this for QGIS 3.0 and use QString::indexOf
>> instead, while providing dedicated regexp functions.
>> What do you think, Mathieu?
>> Matthias
>> On 11/07/2016 12:26 PM, Mathieu Pellerin wrote:
>> > We should indicate in the function help that strpos is regexp based.
>> > On Nov 7, 2016 6:23 PM, "Matthias Kuhn" <matthias at opengis.ch
>> > <mailto:matthias at opengis.ch>> wrote:
>> >     Hi,
>> >     strpos is based on regexp, a '.' matches any character.
>> >     To let the engine treat a . as such you need to prefix it with a
>> >     double-backslash.
>> >     strpos(to_string("area"), '\\.')
>> >     Regards
>> >     Matthias
>> >     On 11/07/2016 12:07 PM, Elstermann, Mike wrote:
>> >     > Hi,
>> >     > “area” is a double-field with values e. g. 213.1234,  43215.3456,
>> >     > strpos("area",'.') gives only value 1 return :-(
>> >     > strpos(to_string("area"),'.') gives only value 1 return  :-(
>> >     > This error exits only by ‘.’, other search-strings e. g. ‘12’,
>> ‘1’, …
>> >     > work fine
>> >     > Our workarround works fine.
>> >     > strpos( replace( to_string( "area" ), '.', ',' ), ',' )
>> >     > Is this a bug with ‘.’?
>> >     > best regards, mikeE.
>> >     > _______________________________________________
>> >     > Qgis-developer mailing list
>> >     > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.o
>> sgeo.org>
>> >     > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >     <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> >     > Unsubscribe:
>> sgeo.org>
>> >     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161107/c7f29dc2/attachment-0001.html>
