[Qgis-developer] BUG? strpos("area",'.') doesn't work
Elstermann, Mike Mike.Elstermann at itc-halle.de
Mon Nov 7 05:24:23 PST 2016
THX to all, that is it.
Tipp in help +1! :-)
mikeE.
Von: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Mathieu Pellerin
Gesendet: Montag, 7. November 2016 12:26
An: Matthias Kuhn
Cc: qgis-developer
Betreff: Re: [Qgis-developer] BUG? strpos("area",'.') doesn't work
We should indicate in the function help that strpos is regexp based.
On Nov 7, 2016 6:23 PM, "Matthias Kuhn" <matthias at opengis.ch<mailto:matthias at opengis.ch>> wrote:
strpos is based on regexp, a '.' matches any character.
To let the engine treat a . as such you need to prefix it with a
double-backslash.
strpos(to_string("area"), '\\.')
Regards
Matthias
On 11/07/2016 12:07 PM, Elstermann, Mike wrote:
> Hi,
> “area” is a double-field with values e. g. 213.1234,  43215.3456, …
> strpos("area",'.') gives only value 1 return :-(
> strpos(to_string("area"),'.') gives only value 1 return  :-(
> This error exits only by ‘.’, other search-strings e. g. ‘12’, ‘1’, …
> work fine
> Our workarround works fine.
> strpos( replace( to_string( "area" ), '.', ',' ), ',' )
> Is this a bug with ‘.’?
> best regards, mikeE.
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161107/6e4d35ab/attachment.html>
