[Qgis-developer] Changing ergonomy of the visibility of layers inside groups ?
Even Rouault even.rouault at spatialys.com
Wed Nov 16 04:01:36 PST 2016
> Grey out is already used to indicate that a checked layer  is currently
> out of its scale range of visibility (hence not visible). so it may be good
> to keep greying layers when they "should" be visible but another option
> makes them not rendered.
Good suggestion
http://www.spatialys.com
