[Qgis-developer] PyQgsOfflineEditingWFS disabled on Travis
Matthias Kuhn matthias at opengis.ch
Wed Nov 16 06:07:35 PST 2016
Following the conversation from
https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
to notify that the PyQgsOfflineEditingWFS has been disabled on the
Travis builds.
Work has been underway to remove "noisy" tests from Travis which cause
false alarms and these tests regularly fail for unrelated changes.
False alarms are bad as they undermine confidence in the CI results
and encourage contributors to ignore the test results.
If you're interested in seeing these tests continue as part of the CI
infrastructure here are some examples of typical random failures these
tests encounter:
https://travis-ci.org/qgis/QGIS/builds/176376751
Best regards
Matthias
