[Qgis-developer] QGIS setup with Qt 5 on mac
Nyall Dawson nyall.dawson at gmail.com
Thu Nov 17 18:11:55 PST 2016
On 18 November 2016 at 11:55, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi,
> Quick update. Success! I've finally built QGIS 3 master branch off of
> unmodified Homebrew dependencies, though had to edit several bits of source
> code and pull some hair out.
Nice work! I'm very keen to see if this fixes some issues we have with
OSX. Specifically, if you remove the ifdef from
https://github.com/qgis/QGIS/blob/master/src/gui/qgscolorbutton.cpp#L505
Does the color picker work?
And if you remove
https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp#L2007
Do preview modes work?
Nyall
> QGIS version: 2.99.0-Master
> QGIS code revision: 6727ea7
> Compiled against: Qt 5.7.0
> Running against Qt: 5.7.0
> Compiled against GDAL/OGR: 2.1.2
> Running against GDAL/OGR: 2.1.2
> Compiled against GEOS: 3.5.0-CAPI-1.9.0
> Running against GEOS: 3.5.0-CAPI-1.9.0 r4084
> PostgreSQL Client Version: 9.6.1
> SpatiaLite Version: 4.3.0a
> QWT Version: 6.1.3
> PROJ.4 Version: 493
> QScintilla2 Version: 2.9.3
> This copy of QGIS writes debugging output.
> and Python 3.5.2.
> http://drive.dakotacarto.com/qgis/qgis3-master_homewbrew-macos-10.11.png
> It's take me a bit more time to commit proper changes, create the qgis3-dev
> formula and add the docs for:
> https://github.com/qgis/homebrew-qgisdev
> Is anyone else already developing QGIS 3 master on Mac?
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> On Tue, Nov 8, 2016 at 1:02 PM, Rouzaud Denis <denis.rouzaud at gmail.com>
> wrote:
>> Hi Larry,
>> Thanks a lot for tackling this!
>> Glad to read it’ll land soon, but no pressure ;)
>> Cheers,
>> Denis
>> On 8 Nov 2016, at 18:13, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Hi,
>> On Sun, Nov 6, 2016 at 7:23 PM, Etienne Trimaille
>> <etienne.trimaille at gmail.com> wrote:
>>> Thanks David and Matthias for providing some feedbacks about QGIS 3 on
>>> mac.
>>> I also would like QGIS 3 compiling on mac.
>>> I hope you will update the install.md on the repo when you will have a
>>> working workflow ? Thanks
>> I have been preparing Homebrew and OSGeo4Mac 'taps' for this move and am
>> now focusing on QGIS 3 formulae, probably starting on Thursday or Friday. I
>> hope to have everything building and docs completed by the end of the
>> weekend.
>> The new formulae will not be hosted in OSGeo4Mac or Homebrew (at least not
>> until there are stable releases), but in a specific tap for QGIS development
>> and Travis CI support:
>> So, look for changes there as things progress. Please contribute or post
>> bug reports there for those dev formulae or docs, once they are available.
>> Regards,
>> Larry Shaffer
>> Dakota Cartography
>>> 2016-11-01 1:22 GMT+07:00 Matthias Kuhn <matthias at opengis.ch>:
>>>> Hi Diane and welcome aboard,
>>>> I also didn't manage to compile master on osx yet.
>>>> Some more information can be found here also:
>>>> https://github.com/OSGeo/homebrew-osgeo4mac/pull/146#issuecomment-254011621
>>>> I think most of the dependencies should meanwhile be available on
>>>> homebrew (but not sure).
>>>> Regards
>>>> Matthias
>>>> On 10/31/2016 06:56 PM, David Marteau wrote:
>>>> > Hi
>>>> > I will speak with my own experience using and compiling Qgis on Mac
>>>> > (El capitan and Maverick):
>>>> > First I use Macport: MacPort use clang/libc++ by default (at least
>>>> > with XCode 5.3 on Maverick, 7.3 on El capitan) so this should solve one of
>>>> > your problems.
>>>> > I have installed qt5 from MacPort without problems.
>>>> > The problems arise with some ports that do not fully support qt5
>>>> > variants and you need to tweak some portfiles: qscintilla and py-qscintilla
>>>> > are one of them and are required by Qgis.
>>>> > If you are interested I can give you my diff files for portfiles.
>>>> > I had to build qwt directly from sources because tweaking Macport
>>>> > portfiles was too painful, but I did not encounter any serious problems as
>>>> > far as I can remember.
>>>> > No source code was needed to be patched, only compilation
>>>> > configurations.
>>>> > Once you get all dependencies you need to set the cmake options
>>>> > accordingly to the path of your installation:
>>>> > Here is my defines:
>>>> > »   »   -DCMAKE_INSTALL_PREFIX:PATH=/Applications \
>>>> > »   »   -DWITH_SERVER=ON \
>>>> > »   »   -DWITH_PYSPATIALITE=ON \
>>>> > -DPYTHON_CUSTOM_FRAMEWORK:PATH=/opt/local/Library/Frameworks/Python.framework
>>>> > »   »   -DEXPAT_INCLUDE_DIR:PATH=/opt/local/include \
>>>> > »   »   -DEXPAT_LIBRARY:FILEPATH=/opt/local/lib/libexpat.dylib \
>>>> > »   »   -DSQLITE3_INCLUDE_DIR:PATH=/opt/local/include \
>>>> > »   »   -DSQLITE3_LIBRARY:FILEPATH=/opt/local/lib/libsqlite3.dylib \
>>>> > -DQT_QMAKE_EXECUTABLE:FILEPATH=/opt/local/libexec/qt5/bin/qmake \
>>>> > -DQWT_INCLUDE_DIR:PATH=/usr/local/qwt-6.1.3/lib/qwt.framework/Versions/6/Headers
>>>> > -DQWT_LIBRARY:FILEPATH=/usr/local/qwt-6.1.3/lib/qwt.framework/Versions/6/qwt
>>>> > »   »   -DQCA_INCLUDE_DIR:PATH=/opt/local/include/qca \
>>>> > »   »   -DQCA_LIBRARY:FILEPATH=/opt/local/lib/libqca.dylib \
>>>> > »   »   -DQSCINTILLA_INCLUDE_DIR:PATH=/opt/local/libexec/qt5/include \
>>>> > -DQSCINTILLA_LIBRARY:FILEPATH=/opt/local/libexec/qt5/lib/libqscintilla2.dylib
>>>> > -DQT_LRELEASE_EXECUTABLE:FILEPATH=/opt/local/libexec/qt5/bin/lrelease \
>>>> > I hope that full support for qt5 will be available from Macport soon,
>>>> > but for now I have managed to compile Qgis from the master branch without
>>>> > struggling too much.
>>>> > Best,
>>>> > David
>>>> >> Le 31 oct. 2016 à 16:12, Diane Perez <lintawa at gmail.com> a écrit :
>>>> >> Dear QGIS developers,
>>>> >> First of all, thank you very much for the great job, I have been a
>>>> >> very happy user for years !
>>>> >> I would like to contribute now to the development, but I found myself
>>>> >> stuck at the installation of dependencies.
>>>> >> According to the instructions of the INSTALL file provided with the
>>>> >> source code, mac users should use Qt 4 and compile and install a bunch of
>>>> >> dependencies for which binaries are not available (mainly Spatialindex, SIP,
>>>> >> QScintilla2, PyQt, Qwt and bison) before being able to compile QGIS. I
>>>> >> followed the instructions and got stuck at compiling QGIS as the master now
>>>> >> requires Qt 5.
>>>> >> Now as I actually started by installing Qt 5 by mistake, I had the
>>>> >> opportunity to see that it leads to a lot of problems to compile the
>>>> >> dependencies. As far as I understand, Qt 5 requires C++11, which means one
>>>> >> must use the new libc++ library instead of the old libstdc++ (at least on my
>>>> >> configuration, with El Capitan and clang/llvm). Some modifications are such
>>>> >> that mixing both is not possible, so everything must be compiled from start
>>>> >> with C++11 and libc++. Unfortunately most of the dependencies I mention
>>>> >> above do not compile without tweaking, and I stopped doing it when it
>>>> >> started meaning not only modifying the Makefiles but the code itself...
>>>> >> I guess some of you work on mac, and have a far better understanding
>>>> >> of all this than me. So my question is : how did you install those
>>>> >> dependencies to compile the last version of QGIS with Qt 5 ?
>>>> >> Did you have to compile again all of them or only a subset using Qt 5
>>>> >> and C++11 ? If so, how did you do it ? I got stuck at Qwt (6.1.3) which uses
>>>> >> lots of functions deprecated in Qt 5.
>>>> >> I hope someone can give me pointers, as I would really like to
>>>> >> contribute to QGIS (and hopefully fix a few bugs bugging me) !
>>>> >> Best regards,
>>>> >> Diane
>>>> >> _______________________________________________
>>>> >> Qgis-developer mailing list
>>>> >> Qgis-developer at lists.osgeo.org
>>>> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
