[Qgis-developer] SAGA and TauDEM algs in QGIS from KingChaos package
Salvatore Larosa lrssvtml at gmail.com
Sun Nov 20 07:11:22 PST 2016
Hi all,
I have installed 2.14.8 from William Kyngesburye's packages, all ok. I
noticed that almost all the algs of SAGA and TauDEM do not work.
For SAGA (2.2.3) algs I get:
/Users/slarosa/.qgis2//processing/saga_batch_job.sh: line 3: 83064
Segmentation fault: 11 saga_cmd io_gdal 0 -TRANSFORM 1 -INTERPOL 0
-GRIDS "/var/folders/h4/ymlf4sqx66g989f8b_mm5pdc0000gn/T/processing45f98c0dfd2042c79bc1adcee612ca04/acef19e7bc864fe29f0453d612165424/elevationutm.sgrd"
-FILES "/Users/slarosa/MU/elevation_utm.tif"
Error: input file
[/var/folders/h4/ymlf4sqx66g989f8b_mm5pdc0000gn/T/processing45f98c0dfd2042c79bc1adcee612ca04/acef19e7bc864fe29f0453d612165424/elevationutm.sgrd]
Error: Zone Grid
That was happening with the Zonal Raster Statistics alg. But I get the
identical error (segmentation fault) with the others algorithms.
For TauDEM algs I get systematically an "Unsupported Data Source" error:
is not a supported raster data source TIFFReadDirectory:Failed to read
directory at offset 1991676
Anyone confirms?
Can I exclude a local problem with my machine (OSX El Capitan)?
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
