[Qgis-developer] Best Practice for QGIS Plugin Help Documentation
C Hamilton adenaculture at gmail.com
Mon Nov 21 09:58:31 PST 2016
Chris,
Thanks for that tip. That is exactly what I needed.
On Sat, Nov 19, 2016 at 12:56 PM, Chris Crook <ccrook at linz.govt.nz> wrote:
> Hi Calvin
> Method 2 is well supported by QGIS.  Put the help in index.html in the
> plugin directory, then
> def showMyPluginHelp(self):
>     from qgis import utils
>     utils.showPluginHelp()
> The showPluginHelp function will look for index.html by default, but you
> can specify a filename to use instead of index.
> It also has a section argument which will go to an html anchor in the help
> file (<a name="mysection">...</a>
> https://github.com/qgis/QGIS/blob/master/python/utils.py#L441
> I'm not sure if this is in the PyQt developers cookbook or in plugin
> builder?
> Cheers
> Chri
> ________________________________________
> From: Qgis-developer [qgis-developer-bounces at lists.osgeo.org] On Behalf
> Of C Hamilton [adenaculture at gmail.com]
> Sent: 19 November 2016 09:13
> To: qgis-developer
> Subject: [Qgis-developer] Best Practice for QGIS Plugin Help Documentation
> As part of my plugins I want to have a Help button that displays the
> documentation. What method do you recommend? I see various authors do it
> differently. I see three methods for when a help button is clicked on.
> 1. Launch a web browser to point to the documentation on the web.
> 2. Have the documentation as a part of the plugin and launch a web browser
> to view it.
> 3. Display a PyQt window with the documentation in it.
> I don't consider #1 as a good option because it fails if you happen to be
> disconnected from the web. What are your thoughts on #2 or #3 or do you
> have a better option?
> Thanks,
> Calvin
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161121/00d23efc/attachment.html>
