[Qgis-developer] PyQgsServerWFST disabled on Travis
Alessandro Pasotti apasotti at gmail.com
Mon Oct 3 03:04:14 PDT 2016
On Mon, Oct 3, 2016 at 11:28 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 3 October 2016 at 19:11, Alessandro Pasotti <apasotti at gmail.com> wrote:
> > On Mon, Oct 3, 2016 at 10:44 AM, Matthias Kuhn <matthias at opengis.ch>
> wrote:
> >> Following the conversation from
> >> https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
> >> to notify that the PyQgsServerWFST has been disabled on the Travis
> builds.
> >> Work has been underway to remove "noisy" tests from Travis which cause
> >> false alarms and these tests regularly fail for unrelated changes.
> >> False alarms are bad as they undermine confidence in the CI results
> >> and encourage contributors to ignore the test results.
> >> If you're interested in seeing these tests continue as part of the CI
> >> infrastructure here are some examples of typical random failures these
> >> tests encounter:
> >> PyQgsServerWFST: https://travis-ci.org/qgis/QGIS/builds/164559513
> >> Matthias
> > Hi Matthias,
> > Is there any way to see the complete build logs for that particular
> build?
> > I'm trying with dash but the interesting part was apparently cut.
> > The rest of the test output was removed since it exceeds the threshold of
> > 307200 bytes.
> If you make the very first output from the test a 'CTEST_FULL_OUTPUT'
> line, then the truncation doesn't occur.
> test_qgsserver_accesscontrol.py uses this, have a look how it's done
> there.
> Nyall
Thanks! I will do it.
BTW, restarting the build https://travis-ci.org/qgis/QGIS/builds/164559513,
the WFS-T test now passes but there is another one that fails:
PyQgsComposerPicture ....................***Timeout  60.00 sec
Should we disable that one too?
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161003/01a7e657/attachment.html>
