[Qgis-developer] Including style on a Qgis plugin
Xavier Barnada xbarnada at gisce.net
Thu Oct 13 23:38:56 PDT 2016
Sorry y hadn't been enought specific. The problem was on the images URLs.
I fixed it with this function:
    def fix_qml_rel_urls(self, url):
        Replaces the QML URLs with plugin relative URLs
        :return:
        plugin_dir = os.path.dirname(os.path.realpath(__file__))
        with open(url, 'r') as fd:
            data = fd.read()
        f = etree.fromstring(data)
        for r in f.xpath('//qgis/renderer-v2/symbols/symbol/layer/prop[@k="
name"]'):
            val = r.get('v')
            parent = r.getparent()
            parent.remove(r)
            rel_url = os.path.join(plugin_dir, val)
            r.set('v', rel_url)
            parent.append(r)
        t = etree.tostring(f, pretty_print=True)
        tmp_url = tempfile.NamedTemporaryFile(suffix='.qml', delete=False)
        tmp_url.write(t)
        tmp_url.close()
        return tmp_url.name
I'm sure that this don't work on all the types of symbols but perhaps is
useful for someone
After patch the style I loaded it.
Best reggards.
Xavier Barnada
2016-10-13 14:27 GMT+02:00 Tom Chadwin <tom.chadwin at nnpa.org.uk>:
> Hi Xavier
> This should give you the path to your plugin's installation folder:
> Hope this is what you need.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/Including-style-on-a-Qgis-plugin-tp5290553p5290560.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161014/54534735/attachment.html>
