[Qgis-developer] Visualisation of relations
Matthias Kuhn matthias at opengis.ch
Sat Oct 15 23:57:39 PDT 2016
Hi Patrick,
Making forms and relations more usable is always welcome.
What exactly are the problems you have with the current solution?
I see that you mentioned the lack of the N:1 side which is available
including add feature, add link, remove feature, remove link pretty much
the way you describe it. On [1] there is some explanation I wrote on the
first implementation.
I think you should have found that since it's shown on the screenshot
which is attached to your mail.
Also lazy loading (load when first visible) was introduced once for
performance reasons and the collapsed state of the group boxes
containing the QgsRelationEditor widget is remembered.
So I think that functionality-wise, most of it should be there already.
With a lot of air left for improvement on the usability side.
Cheers
Matthias
[1] http://blog.vitu.ch/10112013-1201/qgis-relations
On 10/07/2016 09:27 AM, Patrick Valsecchi wrote:
> Hi,
> I'm tasked with making QGIS a bit more usable with complex database
> schemas having a lot of relations (up to hundreds of linked tables). The
> INSPIRE people were a bit too inspired when creating their data schemas
> and now we have to try to make QGIS able to cope with that.
> My concerns with the current situation (as of QGIS master) are:
>   * We can specify the relations between the layers at the project level
>     (it's now easier with the auto-discover feature for PostGIS and
>     Spatialite). But those are only showing in the QgsAttributeForm for
>     the 1-N side (the side that doesn't have the foreign key). Why not
>     on the N-1 side?
>   * For showing the N-1 side in the QgsAttributeForm, one can define a
>     Join in the layer's properties, but I don't see the point of having
>     to define it here as well when we have already the relations info at
>     the project level. I see a use for special joins, but for relations,
>     I don't see why we have to define it twice. And the way it's
>     displayed is not allowing to create joins or edit the joined fields.
>   * I let you imagine the look of the feature attribute form when there
>     are hundreds of directly and indirectly linked tabled. This is just
>     not usable if we display all of them directly like that. Just look
>     at the attached screen shot that shows what happens by default with
>     only 3 tables. It's already a mess.
> Now, what I propose is:
>   * Not expand the relation widget (QgsCollapsibleGroupBox) by default
>     and build it's content only when it is expanded the first time
>     (think of what would happen when you have loops in the schema).
>   * Show N-1 relations as well, in a collapsed by default
>     QgsCollapsibleGroupBox, including a way to add a new linked entry,
>     remove the link (put the FK to NULL) and delete it.
>   * Add a button to open a related feature in a new window.
> What do you guys think?
> Thanks.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
