[Qgis-developer] About my plugins ...
geodrinx at gmail.com geodrinx at gmail.com
Sun Oct 16 11:25:03 PDT 2016
Inviato da iPhone
> Il giorno 16 ott 2016, alle ore 19:45, G. Allegri <giohappy at gmail.com> ha scritto:
> QGIS plugins must me lisenced as GPL, because the depend on QGIS and GPL is viral.
> Anyway distributing only .pyc is not advisible, because they assume the same interpreter and the same execution environment that compiled the .pyc bytecode.
Daccordo è "sconsigliato", e so che funziona.  Ma, mi chiedo, non si sta tentando di aggirare la licenza ?
Cioè, mettiamo che non sia possibile ottenere i sorgenti in chiaro, per qualche ragione (oscurati, per esempio).
Il fatto di non poter leggere i sorgenti in chiaro, come ci assicura che non contengano codice malevolo ?
Non sarebbe meglio vietare questa pratica ?
Che dici ?
Translation:
Agree is "advisable", and I know it works. But, I ask, you are not trying to circumvent the license?
That is, let's say you can not get the clear springs, for some reason (obscured, for example).
The fact that they can not read in light sources, assures us that do not contain malicious code?
Would not it be better to prohibit this practice?
What do you say ?
Thank you
Roberto
> giovanni
> Il 16 ott 2016 18:12, "Geo DrinX" <geodrinx at gmail.com> ha scritto:
>> Well.  You convinced me.
>> I have a question. It is possible to deploy a QGIS plugin providing only compiled files through an external repository, which is added to the repository list? It is absolutely not my case, but I know that someone is doing it.
>> It is normal or license is violated ?
>> Thank you for any info about this.
>> Roberto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161016/b31c663b/attachment.html>
