[Qgis-developer] About my plugins ...
Geo DrinX geodrinx at gmail.com
Mon Oct 17 03:20:15 PDT 2016
Ok, I will try to be more clear (compatibly with my bad English).
Look at this:  https://goo.gl/WR8LVF
In this project, since now, they (public administration) are using QGIS.
But, they have today BIG PROBLEMS with crashes.
In the next version of the system, the NEED to have a secure program (and
possibly open source).
QGIS now is NOT secure.     I explained enough  ?
Now you understand what's at stake?
I hope so.    Now somebody wants to see with me how to make sure QGIS decently
Thank you
Geo
2016-10-17 11:56 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi all,
> I like the *idea* of sandboxing.
> And we all know and agree it's a complex topic. Hard to impossible to
> get right (let's admit also that security is always something gray and
> not black and white - unless the network plug is removed and the room
> isolated with tin foil). This on the other hand doesn't mean that there
> are some approaches which are just wrong by design.
> There is also the question about the level on which sandboxing should
> happen. E.g. distributing the app with flatpak and relying on its portal
> mechanism [1] might at one point in the future be a way to get sandboxing.
> One can also run the app inside some other virtualized environment or
> even separate physical machine already now for isolation.
> Maybe Pypy is a way to get there as well from the python side. I don't
> know. But Nathan is absolutely right that the API offered by Qt builds a
> big attack surface for which someone has to first bring up a sensible
> idea for how to lock attackers down without restricting possibilities
> offered for plugins. Or how to safely decide if running code from
> external shared libs like the processing lwgeom provider does [2] is
> something safe to do or not.
> If someone seriously wants to follow this route:
> Be prepared to work with specialists in this area and do serious
> research about possibilities and feasibility first.
> Be prepared to maintain a separate distribution of QGIS with restricted
> python access and reduced plugin functionality.
> Be prepared to get a very big sponsor to back the effort.
> Matthias
> [1] https://github.com/flatpak/flatpak/wiki/Portals
> [2] https://plugins.qgis.org/plugins/processinglwgeomprovider/
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161017/85b953c6/attachment.html>
