[Qgis-developer] ogrLayerName in processing/tools/vector.py
Sandro Santilli strk at kbt.io
Tue Oct 18 02:59:04 PDT 2016
On Tue, Oct 18, 2016 at 11:55:21AM +0200, Mark Johnson wrote:
> > The problem, as Germán found out, is that the URI passed as parameter
> > is not necessarely an OGR provider URI, but a generic QGIS uri, from
> > any provider, so it cannot always be opened via ogr.Open.
> Yes, ogr-sysntax must be used.
> # -- Spatialite provider
> # dbname='/tmp/x.sqlite' table="t" (geometry) sql='
> would need to call 'GetLayerByName'
But the above is NOT an ogrDataSource
Please see with current master_2 branch if the test work for you
with both GDAL 1 and GDAL 2:
Running the automated test is done via:
  ctest -V -R ProcessingToolsTest
Manual tests imply importing layers to postgis (via processing).
They pass here with GDAL 2
--strk;
