[Qgis-developer] ogrLayerName in processing/tools/vector.py
Mark Johnson mj10777 at googlemail.com
Tue Oct 18 03:08:55 PDT 2016
> But the above is NOT an ogrDataSource
yes, but you are using the OGR-API directly
- so you must use the OGR-Syntax
i.e. you must 'translate' the syntax used in QgsSpatiaLiteProvider to
something OGR will understand.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161018/db5dbbb7/attachment.html>
