[Qgis-developer] Building and debugging QGIS on Windows x64
Frits van Veen fritsvanveen at ziggo.nl
Thu Oct 20 02:07:06 PDT 2016
Hi Casper
I did some sleuthing on the problem of the not working pyuic-wrapper.bat.
The second parameter is wrong. It points to d:\QGIS\Master_2\Build\output\bin\ but should point to d:\QGIS\Master_2\Build\output\bin\RelWithDebInfo.
The problem originates in several vcxproj files and that’s because in PyQtMacros.cmake the variable CMAKE_BUILD_TYPE is empty.
You can see in package-nightly.cmd that CMAKE_BUILD_TYPE is set to RelWithDebInfo, so I did this also in CMakeLists.txt with the line SET(CMAKE_BUILD_TYPE "RelWithDebInfo").
Now the original pyuic-wrapper.bat can be used again.
One minor point: in the vcxproj files all calls to pyuic-wrapper.bat specify the RelWithDebInfo path. But then you only build the RelWithDebInfo anyway.
Another mystery solved ;-)
Frits
View this message in context: http://osgeo-org.1560.x6.nabble.com/Building-and-debugging-QGIS-on-Windows-x64-tp5291058p5291658.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161020/0f2a8bff/attachment.html>
