[Qgis-developer] Labelling in QGIS Server/Lizmap
René-Luc Dhont rldhont at gmail.com
Fri Oct 21 02:00:55 PDT 2016
What would be very nice is 2 new parameters:
* withlabels=False
* onlylabels=True
In GetMap request.
Regards,
Le 21/10/2016 à 10:57, Matthias Kuhn a écrit :
> What would be very nice would be a way to render labels client side.
> Probably not so easy (and maybe only with support for a subset of
> labeling options) but imagine the UX!
> Matthias
> On 10/21/2016 10:46 AM, René-Luc Dhont wrote:
>> Hi Paolo,
>> It's not a qgis server issue!
>> It's just the way lizmap querying QGIS Server: One layer at a time! So
>> impossible labelling checking under multiple layer.
>> If you want exactly the sae rendering has QGIS, lizmap has to implement
>> a way to query all the layer in 1 request.
>> Regards,
>> Le 21/10/2016 à 10:08, Paolo Cavallini a écrit :
>>> Hi all,
>>> when publishing a complex project in Lizmap, label collisions are
>>> checked only within a layer or group, and not, as in QGIS Desktop,
>>> across the project. This is a serious limitation for cartographic
>>> projects. I cannot think of a solution to this: am I missing something?
>>> All the best, and thanks.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
