[Qgis-developer] Fill nodata gdal tool in gdal-plugin using Leveller as outputformat
Giovanni Manghi giovanni.manghi at gmail.com
Mon Oct 24 01:45:52 PDT 2016
> Hi,
> I am trying to use the Fill nodata tool from the Raster menu (and so the
> gdal-plugin) but it fails to use the default out format which seems to be
> set to Leveller. Changing the code in the box to -of GTiff solves the
> problem but I wonder why the Leveller format is not working.
> I am running QGIS 2.14.7, with GDAL 1.11.3 in Ubuntu 16.
> Is it related to the GDAL library version?
I have just tried (same platform, same qgis version) and can't
confirm. If in the output dialog you choose "tif" the gdal command is
properly change with -of Gtiff (and similarly for the other formats).
Check if have an old version of gdaltools in your plugin folder.
cheers!
-- G --
