[Qgis-developer] Qgis private plugin repository
Alessandro Pasotti apasotti at gmail.com
Sat Oct 29 12:22:12 PDT 2016
On Sat, Oct 29, 2016 at 4:14 PM, Borys Jurgiel <lists at borysjurgiel.pl>
wrote:
> Dnia piątek, 28 października 2016 13:58:53 Alessandro Pasotti pisze:
> > You can also avoid any server-side scripting completely if you create a
> set
> > of static filtered XMLs for the different QGIS versions and you serve
> them
> > statically after some url rewriting (Apache or Nginx doesn't really
> matter).
> I guess there is no need to create the set of xmls. Just one static file
> with
> all the plugin versions is enough, as the QgisMinimumVersion and
> QgisMaximumVersion tags will do the job. I believe the reason you
> implemented
> the sever-side filtering was to limit the response size, what isn't any
> problem
> in a small repo.
> Regards,
> Borys
Hi Borys,
you are absolutely right, this was the reason for the official repo, if you
don't have many plugins I think you can  safely use a static XML and let
the client do the version filtering.
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161029/9e5c383f/attachment.html>
