[Qgis-developer] FOSS4G code sprint idea: improving SLD export and GeoServer compatibility
René-Luc Dhont rldhont at gmail.com
Fri Sep 2 09:57:48 PDT 2016
Hi Andrea,
I have backported your works:
https://github.com/qgis/QGIS/pull/3448
It needs some tests and reviews.
Regards,
René-Luc
Le 01/09/2016 à 21:41, Andrea Aime a écrit :
> Hi Anita,
> sorry for the late reply, busy times, and I knew the response would be
> long.
> The update is ... complicated :-)
> So, around the sprint a few issues were fixed and have code merged in
> master (QGis 3.x):
>   * Export of ogc:Filter in places where an expression is required,
>     used to happen for any non zero rotation and any non fully opaque
>     alpha, making the SLD invalid/unreadable. Pull request here,
>     merged on master: https://github.com/qgis/QGIS/pull/3366
>   * The styling works by default in "on screen mm", but SLD does not
>     have such notion (has on screen pixel, on ground meter, on ground
>     feet), and QGis did not rescale the values, making for very thin
>     lines and tiny symbols. Fixed in this pull request, merged on
>     master: https://github.com/qgis/QGIS/pull/3414
>   * Scale based visibility declared at the layer level was not
>     exported in SLD, making for layers that would show up at all zoom
>     levels. Pull request here, merged as well:
>     https://github.com/qgis/QGIS/pull/3436
>   * GeoServer/GeoTools could not handle the way font based marks were
>     exported. The syntax was actually valid, so I decided to build
>     support for QGis own convention in GeoTools. This is the only bit
>     already available in all supported GT/GS branches (develop,
>     stable, maintenance): https://osgeo-org.atlassian.net/browse/GEOT-5496
>   * QGis exports as "well known mark" names values that are not
>     actually "well known", this one in being solved in
>     GeoTools/GeoServer by adding support for the same names. Pull
>     request pending, still haven't had the time to check it out:
>     https://github.com/geotools/geotools/pull/1288
>   * Labels are not exported at all as TextSymbolizer, during the
>     spring Raymond Nijssen started working on that, he's got a
>     promising work in progress, not yet turned into a pull request
> Kudos to the QGis developers that helped me with discussion,
> suggestions, and pull request reviews :-)
> Yet, there is still quite a lot of work to be done. Off the top of my
> head:
>   * Backporting some/all of the above to QGis 2.16 and maybe 2.14
>   * QGis has a nice support for "parametric" SVG based on a draft SVG
>     extension that never became "official", basically, it allows to
>     have SVG with parameters for stroke color, width and opacity, fill
>     color and opacity. GeoTools does not recognize such extension and
>     always renders SVG symbols full black. I intend to add this
>     support to GT/GS, see
>     http://osgeo-org.1560.x6.nabble.com/Adding-support-for-parametric-SVGs-td5282722.html
>     , and then enrich the QGis export to add said params in the SLD.
>     Mind, right now the export QGis is doing is also invalid, it's
>     adding tags trying to support the stroke related params that are
>     not part of the SLD standard. I hope to be able to build this on
>     the GeoTools side before September 18th, the feature freeze date
>     for the next GT/GS release, but no promises.
>   * Alignment (top/bottom/left/right) is well supported in SLD, but
>     the current QGis exported does not write the appropriate tags.
>     Should not be too hard to fix, but there might be several places
>     in the code to change.
>   * There is no support to export symbology where values are gathered
>     from a property, or an expression based on properties. SLD
>     supports this from day 0, but the SLD export code has no ability
>     to support that. It would be nice to have basic support for
>     property names, arithmetic, maybe some mapping between QGis own
>     functions and GT/GS functions usable in SLD (full list here, can
>     be easily extended:
>     http://docs.geoserver.org/stable/en/user/filter/function_reference.html
>     ). This would be a massive undertaking, I'm afraid it won't be
>     feasible without funding, but we'll see (note, all the work I did
>     so far was unfunded).
>   * There is no support for exporting raster symbology, colormaps,
>     contrast stretch and the like. GeoServer also does not understand
>     SLD 1.1 raster symbology (it's quite different from the SLD 1.0
>     one), so work will have to be done on both sides. Seems another
>     large undertaking.
>   * x/y translation/offset for lines and polygons is not implemented
>     in GeoServer (only for points and labels instead), that would
>     require some work, but not too much
>   * Compositing/blending is supported in GeoServer as a SLD extension,
>     could be thus exported (cannot promise all single
>     compositing/blending modes are a match on the two sides)
>   * Pseudo 3D buildings are supported as an extension in GeoServer
>     SLD, so this kind of layer is probably exportable. Might need some
>     work on the GeoServer side to render the same way as QGis though
>     (as far as I know QGis is doing some sorting). Example style for
>     GeoServer and map here:
>     https://github.com/charleyglynn/Extruded-buildings-SLD
>   * z-stacked symbols like "highway" roads (paint all roads orange
>     thick, go back, paint all roads white thin) are supported on both
>     sides, but the export does not support it, and some change in the
>     overall export logic would be required to actually support it, as
>     SLD requires multiple FeatureTypeStyle elements, one per z level,
>     to be generated in order to get the same effect. Right one there
>     is just one FTS with many rules and symbolizers in it.
>   * Geometry generators can probably be partially translated as
>     "geometry transformations" in SLD, except in our case they do work
>     in real world coordinates, not on screen:
>     http://docs.geoserver.org/stable/en/user/styling/sld-extensions/geometry-transformations.html
>   * Some types of symbology like shapeburst and inverted polygons are
>     simply not available in SLD, nor in GeoServer own extensions, so
>     one would have to first implement those in GeoServer, create
>     appropriate SLD extensions, and then have QGis implement them in
>     the output
> I'm probably forgetting something, and likely unaware of other QGis
> mapping capabilities I did not mention above :-)
> In any case, my target for the sprint was to show that exporting
> _basic_ styling is feasible, and does not require months of work. To
> some extent that was achieved (especially when we get the text
> symbolizer support). Hopefully it will make more people interested,
> maybe some devs will pitch in, and some sponsoring organizations can
> fill in the blanks.... an open source developer can dream, right? :-p
> Cheers
> Andrea
> On Tue, Aug 30, 2016 at 8:42 PM, Anita Graser <anitagraser at gmx.at
> <mailto:anitagraser at gmx.at>> wrote:
>     Hi everyone!
>     Hope you made it back home safe after Bonn. Could you give a short
>     update on this topic, what was discussed / decided / worked on in
>     Bonn?
>     Thank you and best wishes,
>     Anita
>     On Sat, Jul 9, 2016 at 10:56 AM, Andrea Aime
>     <andrea.aime at geo-solutions.it
>     <mailto:andrea.aime at geo-solutions.it>> wrote:
>         On Tue, Jun 28, 2016 at 7:42 PM, Andrea Aime
>             I'll be at the code sprint after the conference, Saturday
>             and Sunday.
>         Change of plans, I'll be there the Sunday before the
>         conference, and due to flight
>         arrangements, also most of Saturday (in case anyone's
>         interested we can find
>         a place to start hacking)
>         Cheers
>         Andrea
>         GeoServer Professional Services from the experts! Visit
>         http://goo.gl/it488V for more information.
>         Ing. Andrea Aime
>         @geowolf
>         Technical Lead
>         GeoSolutions S.A.S.
>         Via di Montramito 3/A
>         55054 Massarosa (LU)
>         phone: +39 0584 962313 <tel:%2B39%200584%20962313>
>         fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
>         mob: +39  339 8844549 <tel:%2B39%20%C2%A0339%208844549>
>         http://www.geo-solutions.it
>         http://twitter.com/geosolutions_it
>         <http://twitter.com/geosolutions_it>
>         *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>         Le informazioni contenute in questo messaggio di posta
>         elettronica e/o nel/i file/s allegato/i sono da considerarsi
>         strettamente riservate. Il loro utilizzo è consentito
>         esclusivamente al destinatario del messaggio, per le finalità
>         indicate nel messaggio stesso. Qualora riceviate questo
>         messaggio senza esserne il destinatario, Vi preghiamo
>         cortesemente di darcene notizia via e-mail e di procedere alla
>         distruzione del messaggio stesso, cancellandolo dal Vostro
>         sistema. Conservare il messaggio stesso, divulgarlo anche in
>         parte, distribuirlo ad altri soggetti, copiarlo, od
>         utilizzarlo per finalità diverse, costituisce comportamento
>         contrario ai principi dettati dal D.Lgs. 196/2003.
>         The information in this message and/or attachments, is
>         intended solely for the attention and use of the named
>         addressee(s) and may be confidential or proprietary in nature
>         or covered by the provisions of privacy act (Legislative
>         Decree June, 30 2003, no.196 - Italy's New Data Protection
>         Code).Any use not in accord with its purpose, any disclosure,
>         reproduction, copying, distribution, or either dissemination,
>         either whole or partial, is strictly forbidden except previous
>         formal approval of the named addressee(s). If you are not the
>         intended recipient, please contact immediately the sender by
>         telephone, fax or e-mail and delete the information in this
>         message that has been received in error. The sender does not
>         give any warranty or accept liability as the content, accuracy
>         or completeness of sent messages and accepts no responsibility
>         for changes made after they were sent or for other risks which
>         arise as a result of e-mail transmission, viruses, etc.
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         <mailto:Qgis-developer at lists.osgeo.org>
>         List info:
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
>         <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>         Unsubscribe:
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse, costituisce comportamento contrario ai principi dettati dal
> D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data Protection Code).Any use not in accord with its purpose, any
> disclosure, reproduction, copying, distribution, or either
> dissemination, either whole or partial, is strictly forbidden except
> previous formal approval of the named addressee(s). If you are not the
> telephone, fax or e-mail and delete the information in this message
> that has been received in error. The sender does not give any warranty
> or accept liability as the content, accuracy or completeness of sent
> messages and accepts no responsibility  for changes made after they
> were sent or for other risks which arise as a result of e-mail
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/ba3947ca/attachment-0001.html>
