[Qgis-developer] Processing qgis:joinattributesbylocation output empty if run from console
Arnaud Morvan arnaud.morvan at camptocamp.com
Thu Sep 8 10:48:52 PDT 2016
Should be fixed with https://github.com/qgis/QGIS/pull/3471
only remove double quotes around "['within']" => ['within'] and it works
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 05/09/2016 19:25, Anita Graser a écrit :
> Hi,
> qgis:joinattributesbylocation seems to produce correct output when run
> from GUI but empty output when called from the console (just copied
> the command from history):
> processing.runalg("qgis:joinattributesbylocation","D:/Documents/Geodata/qgis_sample_data/shapefiles/popp.shp","D:/Documents/Geodata/qgis_sample_data/shapefiles/regions.shp","['within']",0,0,"sum,mean,min,max,median",0,None)
> It also runs much faster on the command line, indicating that it's not
> actually processing the data (because it's much slower through the GUI).
> Can anyone reproduce? I use OSGeo4W version 2.16.
> Best wishes,
> Anita
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160908/3a7d602e/attachment.html>
