[Qgis-developer] qgis kartoza docker images, use configpath option?
Luigi Pirelli luipir at gmail.com
Mon Sep 26 06:46:57 PDT 2016
http://stackoverflow.com/questions/19537645/get-environment-variable-value-in-dockerfile
then set env that will be used in the start.sh
I did the base of 2.14 dockerfile... but I didn't follow it's
evolution... probably there is an issue.
better than a issue, would be fine a PR :) edit Dockerfile is a really
simple beast ;)
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 26 September 2016 at 14:16, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi there,
> I'm trying to set up multiple docker images to test different environments
> in ubuntu xenial.
> I just gave a try to excellent Tim's repository with  docker images for all
> QGIS versions.
> My question : Is it possible to launch a docker image with --configpath
> option as an argument so that I can use differents qgis profiles with one
> image?  If yes, how can I achieve that?
> Thanks for your lights.
> BTW, I could run QGIS master but 2.14.6 returns that error:
> docker: Error response from daemon: oci runtime error: exec: "/start.sh":
> stat /start.sh: no such file or directory.
> Shall I create an issue in kartoza repo?
> Régis Haubourg
> Attention, changement d'adresse mail!
> Mon adresse principale devient désormais regis.haubourg at gmail.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
