[Qgis-developer] QGIS Server 3.0 roadmap
René-Luc Dhont rldhont at gmail.com
Tue Sep 27 00:35:11 PDT 2016
Hi Régis and Luca,
The other point, unique's id, is due to the fact that QGIS and QGIS
Server does not truth the QGIS Layer Description and verifying the
unicity of ids. So to avoid id, the layer has to be added with
'estimated metadata'.
If a PostGIS layer has not been opened with this option, the user has to
update the datasource to add it.
Regards,
Le 27/09/2016 à 09:29, Régis Haubourg a écrit :
> Le mardi 27 septembre 2016 à 09:25 +0200, Luca Manganelli a écrit :
>> way in which qgis server does the same PostGis
>> query (for extent or bounding box?) all times for each layer. It woud
>> be useful to store these informations on the project file, to optimize
>> times, with a configuration option in the Server tab?
> Hi, on this part, improvements have been made recently since this was a blocker in my previous employer's architecture and we
> funded 3Liz to improve things.
> René Luc, can you summarize what is the current status on postgis extent and unique id's queries?
> Cheers
> Régis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
