[Qgis-developer] CI testing: the straight truth
Nathan Woodrow
madmanwoo at gmail.com
Tue Jan 3 19:18:29 PST 2017
How long does the build vs test run itself take?
- Nathan
On Wed, Jan 4, 2017 at 8:40 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 4 January 2017 at 07:59, Matthias Kuhn <matthias at opengis.ch> wrote:
> > Hi René-Luc, hi all,
> > This is something I have been afraid of for a couple of weeks.
> > Short story: our builds just grew too big and a full build is taking
> > more than 50 minutes to complete on the travis infrastructure.
> Argh... what a pain! Still, I think in some ways this is a good
> reflection of the exponential growth in QGIS unit tests since your
> initial work introducing the CI infrastructure. I certainly would
> never want to go back to the pre-CI days!
> Just wondering- is there any chance sending an email to the Travis
> crew could get an extension to this build time? I can't see anything
> on their publicised plans, but perhaps they have a cheaper unlimited
> build time option available for open source projects?
> I'd like to see us exhaust these "easier" options first before
> requiring someone to donate time into tweaking/changing the CI
> infrastructure.
> Nyall
> >What
> > keeps us alive at the moment is the persistent ccache so a full build
> > actually never happens. If the ccache gets lost, we will need some black
> > magic to get the builds started again (it's possible to slowly get the
> > cache warm but not straightforward).
> > What we could possibly do:
> > - Modularize the build: e.g. astyle could very well be moved to a
> > separate job along with other static checks like spelling. That would
> > even have the advantage of a faster feedback for these analyses.
> > But I'm not sure how much time we can actually get out of that.
> > - Move dependencies into separate packages. We have some deps like
> > qspatialite that are built as part of QGIS which I think could be
> > installed as dependencies from a .deb. This will require quite a bit
> > of work: moving travis out of the container based infrastructure to
> > the sudo-enabled infrastructure, setting up a repo (e.g. ppa) with
> > all sort of dependencies including qt 5 etc. This would be an option
> > again since travis enabled caching also on sudo systems recently.
> > This will be a quite large task to do.
> > - Move to another system (managed infrastructure or self-hosted, there
> > are a couple of services like circle ci, drone.io, jenkins, gitlab
> > ci ...).
> > This will be a quite large task to do with the risk that we run into
> > yet another timeout, other technical issue or run a self-hosted
> > infrastructure for which nobody really has the resources to maintain.
> > Apart from this, there is also the dependency on some pre-compiled
> > libraries in the osgeo4a repository. Keeping these up to date is not
> > something we will want in the long term (I was hoping that travis would
> > ship a more recent distro than trusty but haven't seen many hints in
> > this direction yet).
> > Bottomline: I don't think there's an easy fix but I think it's time to
> > start thinking about the future.
> > Matthias
> > On 01/02/2017 03:03 PM, René-Luc Dhont wrote:
> >> Hi Devs,
> >> I would like to merge a PR https://github.com/qgis/QGIS/pull/3897 but
> >> Travis cannot ccomplete the tests.
> >> Would it be simple to fix travis ?
> >> Regards,
> >> René-Luc
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170104/377eef37/attachment.html>
