[Qgis-developer] CI testing: the straight truth
Larry Shaffer larrys at dakotacarto.com
Wed Jan 4 16:10:26 PST 2017
On Wed, Jan 4, 2017 at 2:31 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Andreas, Nyall
> I would also prefer this, I just sent them a mail and will get back to
> you as soon as I get a response.
As a side note to this, I see very little use of [ci skip] in commit
messages [0]. If we are asking Travis to help us out with unlimited (or
longer) build times, it would be neighborly of us to add to our developer
docs (and maybe new PR template) some information on recommended use of [ci
skip] for trivial or non-build/testing-related commits.
Building QGIS jobs certainly must eat a bunch of Travis resources. It would
be good of us to try to ensure extraneous builds are not initiated.
Does anyone know if adding [ci skip] to the merge commit of a PR (that has
already passed tests) skips a CI build on the merged-into branch?
[0] https://docs.travis-ci.com/user/customizing-the-build#Skipping-a-build
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Mid-term we will still need to launch a project to update the system and
> get away from the pre-built dependencies in osgeo4travis to a system
> that is easier to maintain collectively but I'm happy if we can wait
> with this a bit.
> @Tom Chadwin:
> agreed, that's a risk indeed
> Best regards
> Matthias
> On 01/04/2017 08:21 AM, Neumann, Andreas wrote:
> > Hi all,
> > I agree with Nyall. We should try contracting the travis ci team and ask
> > them if we could switch to unlimited build time. Even if this means
> > paying a certain amount for the services (if it is a reasonable price).
> > Matthias - could you please take a lead in contacting them?
> > Thanks,
> > Andreas
> > On 2017-01-03 23:40, Nyall Dawson wrote:
> >> On 4 January 2017 at 07:59, Matthias Kuhn <matthias at opengis.ch
> >> <mailto:matthias at opengis.ch>> wrote:
> >>> Hi René-Luc, hi all,
> >>> This is something I have been afraid of for a couple of weeks.
> >>> Short story: our builds just grew too big and a full build is taking
> >>> more than 50 minutes to complete on the travis infrastructure.
> >> Argh... what a pain! Still, I think in some ways this is a good
> >> reflection of the exponential growth in QGIS unit tests since your
> >> initial work introducing the CI infrastructure. I certainly would
> >> never want to go back to the pre-CI days!
> >> Just wondering- is there any chance sending an email to the Travis
> >> crew could get an extension to this build time? I can't see anything
> >> on their publicised plans, but perhaps they have a cheaper unlimited
> >> build time option available for open source projects?
> >> I'd like to see us exhaust these "easier" options first before
> >> requiring someone to donate time into tweaking/changing the CI
> >> infrastructure.
> >> Nyall
> >>> What
> >>> keeps us alive at the moment is the persistent ccache so a full build
> >>> actually never happens. If the ccache gets lost, we will need some
> black
> >>> magic to get the builds started again (it's possible to slowly get the
> >>> cache warm but not straightforward).
> >>> What we could possibly do:
> >>>  - Modularize the build: e.g. astyle could very well be moved to a
> >>>    separate job along with other static checks like spelling. That
> would
> >>>    even have the advantage of a faster feedback for these analyses.
> >>>    But I'm not sure how much time we can actually get out of that.
> >>>  - Move dependencies into separate packages. We have some deps like
> >>>    qspatialite that are built as part of QGIS which I think could be
> >>>    installed as dependencies from a .deb. This will require quite a bit
> >>>    of work: moving travis out of the container based infrastructure to
> >>>    the sudo-enabled infrastructure, setting up a repo (e.g. ppa) with
> >>>    all sort of dependencies including qt 5 etc. This would be an option
> >>>    again since travis enabled caching also on sudo systems recently.
> >>>    This will be a quite large task to do.
> >>>  - Move to another system (managed infrastructure or self-hosted, there
> >>>    are a couple of services like circle ci, drone.io, jenkins, gitlab
> >>>    ci ...).
> >>>    This will be a quite large task to do with the risk that we run into
> >>>    yet another timeout, other technical issue or run a self-hosted
> >>>    infrastructure for which nobody really has the resources to
> maintain.
> >>> Apart from this, there is also the dependency on some pre-compiled
> >>> libraries in the osgeo4a repository. Keeping these up to date is not
> >>> something we will want in the long term (I was hoping that travis would
> >>> ship a more recent distro than trusty but haven't seen many hints in
> >>> this direction yet).
> >>> Bottomline: I don't think there's an easy fix but I think it's time to
> >>> start thinking about the future.
> >>> Matthias
> >>> On 01/02/2017 03:03 PM, René-Luc Dhont wrote:
> >>>> Hi Devs,
> >>>> I would like to merge a PR https://github.com/qgis/QGIS/pull/3897 but
> >>>> Travis cannot ccomplete the tests.
> >>>> Would it be simple to fix travis ?
> >>>> Regards,
> >>>> René-Luc
> >>>> _______________________________________________
> >>>> Qgis-developer mailing list
> >>>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org
> >>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170104/66276586/attachment.html>
