[QGIS-es] Problema al usar el plugin rt_mapserver_exporter-0.4.0
Francisco Salas Rosette fsalas en pinar.geocuba.cu
Mie Jul 8 08:28:55 PDT 2015
Hola a todos ,
tengo instalado Qgis 2.8.2 en Windows 7 64bit , descargue recientemente el
plugin para exportar a  mapserver,  “rt_mapserver_exporter-0.4.0”, cuando
trato de usarlo me da este error :
Ha ocurrido un error mientras se ejecutaba el código de Python:
  File
"C:/PROGRA~2/QGISWI~1/apps/qgis/./python/plugins\rt_mapserver_exporter\plugi
n.py", line 65, in run
    from .mapfileexportdlg import MapfileExportDlg
  File "C:/PROGRA~2/QGISWI~1/apps/qgis/./python\qgis\utils.py", line 478, in
_import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File
"C:/PROGRA~2/QGISWI~1/apps/qgis/./python/plugins\rt_mapserver_exporter\mapfi
leexportdlg.py", line 30, in
    import mapscript
_import
ImportError: No module named mapscript
Versión de Python:
2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
Versión de QGIS:
2.8.2-Wien Wien, 1b929ef
Seguí estas instrucciones para tratar de solucionarlo “
<http://gis.stackexchange.com/questions/132219/installing-python-mapscript-b
indings-on-windows> Installing Python MapScript Bindings on Windows”  y me
sale este error
python setup.py install
running install
running bdist_egg
running egg_info
writing requirements to mapscript.egg-info\requires.txt
writing mapscript.egg-info\PKG-INFO
writing top-level names to mapscript.egg-info\top_level.txt
writing dependency_links to mapscript.egg-info\dependency_links.txt
reading manifest file 'mapscript.egg-info\SOURCES.txt'
writing manifest file 'mapscript.egg-info\SOURCES.txt'
installing library code to build\bdist.win32\egg
running install_lib
running build_py
creating build
creating build\lib.win32-2.7
copying mapscript.py -> build\lib.win32-2.7
running build_ext
building '_mapscript' extension
error: Unable to find vcvarsall.bat
O sea es un problema detras de otro , ¿ Alguien puede orientarme como
solucionar estos problemas?
Saludos
Francisco Salas
Anuncie sus servicios en ANDARIEGO
 aplicación para celulares sobre mapas de toda Cuba.
Visite el sitio http://andariego.geocuba.cu o http://www.andariego.cu, contáctenos por el correo andariego en geosi.geocuba.cu o por el teléfono 8817400.
Ponga su información al servicio de todos.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20150708/09e42cbc/attachment-0002.html>
Más información sobre la lista de distribución QGIS-es
