[QGIS-es] Problemas con qgis_mapserv.fcgi.exe
Francisco Salas Rosette fsalas en pinar.geocuba.cu
Sab Jul 11 06:33:06 PDT 2015
Hola , no sé si estoy preguntando en la lista adecuada este problema que
tengo , pero no se de una lista de QGis Server.
El problema es que tengo en mi PC (Windows 7 64bit), funcionando bien
QGisServer mediante OSGeo4W , y se ejecuta bien QGIS-Web-Client-master , a
la hora de copiar la carpeta OSGeo4W , para otra PC con iguales
características , se ejecuta
http://localhost:8081/ y aparece bien esta información.
OSGeo4W - OSGeo for Windows
Installed Web Applications and Features
There is currently 1 osgeo4w application installed.
PHP 5.2.5:
Pero cuando ejecuto esto en el navegador
http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS
<http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUE
ST=GetCapabilities> &VERSION=1.3.0&REQUEST=GetCapabilities
Me da un error y en el fichero log se registra la información que se muestra
a continuación:
The Apache OSGeo4W Web Server service has restarted.
restart signal -- Restarting the server.
[Fri Jul 10 11:30:55 2015] [notice] Child 4588: Exit event signaled. Child
process is ending.
[Fri Jul 10 11:30:55 2015] [warn] module cgi_module is already loaded,
skipping
[Fri Jul 10 11:30:55 2015] [notice] Apache/2.2.14 (Win32) configured --
resuming normal operations
[Fri Jul 10 11:30:55 2015] [notice] Server built: Sep 28 2009 22:41:08
[Fri Jul 10 11:30:55 2015] [notice] Parent: Created child process 2948
skipping
skipping
[Fri Jul 10 11:30:55 2015] [notice] Child 2948: Child process is running
[Fri Jul 10 11:30:56 2015] [notice] Child 4588: Released the start mutex
[Fri Jul 10 11:30:56 2015] [notice] Child 2948: Acquired the start mutex.
[Fri Jul 10 11:30:56 2015] [notice] Child 2948: Starting 64 worker threads.
[Fri Jul 10 11:30:57 2015] [notice] Child 4588: All worker threads have
exited.
[Fri Jul 10 11:30:57 2015] [notice] Child 4588: Child process is exiting
[Fri Jul 10 11:30:57 2015] [notice] Child 2948: Starting thread to listen on
port 8081.
[Fri Jul 10 11:31:02 2015] [error] [client 127.0.0.1] Premature end of
script headers: qgis_mapserv.fcgi.exe
Sin embargo en otra PC funciona bien , pero en otras no , ¿Alguien pudiera
orientarme como solucionar este problema?
Saludos cordiales,
Francisco Salas
Anuncie sus servicios en ANDARIEGO
 aplicación para celulares sobre mapas de toda Cuba.
Visite el sitio http://andariego.geocuba.cu o http://www.andariego.cu, contáctenos por el correo andariego en geosi.geocuba.cu o por el teléfono 8817400.
Ponga su información al servicio de todos.
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20150711/37b238a0/attachment-0002.html>
Más información sobre la lista de distribución QGIS-es
