[QGIS-es] Problemas con procesos GRASS
Pablo Schweitzer pablosarg en gmail.com
Sab Sep 24 13:57:45 PDT 2016
Hola
Necesito calcular distancias entre puntos usando una red de rutas, por lo
que estoy explorando las distintas herramientas v.net ... pero no logro
entender como funcionan. Por ejemplo el v.net.distance resulta en:
Algoritmo v.net.distance - Computes shortest distance via the network
between the given sets of features. comenzando...
g.proj -c proj4="+proj=tmerc +lat_0=-90 +lon_0=-60 +k=1 +x_0=5500000 +y_0=0
+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
v.in.ogr min_area=0.0001 snap=-1
input="/tmp/processingbf3a2cb8557f4ee8af785f1fed0b4a81/edabaf3427c34746b96bc4040bd059fc"
layer=RedVial output=tmp14747504593747 --overwrite -o
input="/tmp/processingbf3a2cb8557f4ee8af785f1fed0b4a81/85f544717fb54897b172ba6ba8a25313"
layer=CentrosPoblados output=tmp14747504593848 --overwrite -o
input="/tmp/processingbf3a2cb8557f4ee8af785f1fed0b4a81/42282af0c7854adaa19176750d30aae4"
layer=CentrosPobladoscopiar output=tmp14747504593849 --overwrite -o
g.region n=4884023.19787 s=4161932.073 e=5065588.72624 w=4553392.96446
res=100
v.net -s input=tmp14747504593747 points=tmp14747504593848
out=tmp14747504593850 op=connect threshold=50 arc_layer=1 node_layer=2
v.db.connect -o map=tmp14747504593850 table=tmp14747504593848 layer=2
v.net -s input=tmp14747504593850 points=tmp14747504593849
out=tmp14747504593851 op=connect threshold=50 arc_layer=1 node_layer=3
v.db.connect -o map=tmp14747504593851 table=tmp14747504593849 layer=3
v.net.distance input=tmp14747504593851 arc_type=line,boundary to_type=point
from_layer="2" to_layer="3" output=outputb5f43166300d412ca1c300cf7a07d550
--overwrite
v.out.ogr -s -e input=outputb5f43166300d412ca1c300cf7a07d550 type=auto
output="/tmp/processingbf3a2cb8557f4ee8af785f1fed0b4a81/f58746b6f48c4f44b3b7a317ee0f37a4"
format=ESRI_Shapefile output_layer=output --overwrite
Iniciando GRASS GIS...
Ejecutando '/home/pablo/.qgis2//processing/grass7_batch_job.sh'...
Default region was updated to the new projection, but if you have multiple
mapsets `g.region -d` should be run in each to update the region from the
default
Projection information updated
ADVERTENCIA: El datum no es reconocido por GRASS y no se han encontrado
parámetros.
Over-riding projection check
Check if OGR layer contains polygons...
0..2..4..6..8..10..12..14..16..18..20..22..24..26..28..30..32..34..36..38..40..42..44..46..48..50..52..54..56..58..60..62..64..66..68..70..72..74..76..78..80..82..84..86..88..90..92..94..96..98..100
Importing 3434 features (OGR layer )...
Construyendo topología para el mapa vectorial ...
Registrando primitivas...
3436 primitives registered
54390 vertices registered
Construyendo áreas.
0 areas built
0 isles built
Adjuntando islas...
Adjuntando centróides...
1..3..5..7..9..11..13..15..17..19..21..23..25..27..29..31..33..35..37..39..41..43..45..47..49..51..53..55..57..59..61..63..65..67..69..71..73..75..77..79..81..83..85..87..89..91..93..95..97..99..100
Número de nodos: 2610.
Número de primitivas: 3436.
Número de puntos: 0.
Número de líneas: 3436.
Número de contornos: 0.
Número de centroides (baricentros): 0.
Número de áreas: 0.
Número de íslas: 0.
parámetros.
0..20..40..60..80..100
Importing 5 features (OGR layer )...
5 primitives registered
5 vertices registered
Construyendo áreas.
0 areas built
0 isles built
Adjuntando islas...
20..40..60..80..100
Número de nodos: 0.
Número de primitivas: 5.
Número de puntos: 5.
Número de líneas: 0.
Número de áreas: 0.
Número de íslas: 0.
parámetros.
0..100
Importing 1 features (OGR layer )...
0..100
One primitive registered
One vertex registered
Construyendo áreas.
0..100
0 areas built
0 isles built
Adjuntando islas...
100
Número de nodos: 0.
Número de primitivas: 1.
Número de puntos: 1.
Número de áreas: 0.
Número de íslas: 0.
Copying features...
2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
Número de áreas: -
Número de íslas: -
Copying attributes...
Construyendo áreas.
0 areas built
0 isles built
Adjuntando islas...
Número de áreas: 0.
Número de íslas: 0.
v.net completo. 0 lines (network arcs) written to output.
The table is now part of vector map and may be deleted or overwritten by
GRASS modules
Select privileges were granted on the table
Copying features...
Número de áreas: -
Número de íslas: -
Construyendo áreas.
0 areas built
0 isles built
Adjuntando islas...
Número de áreas: 0.
Número de íslas: 0.
GRASS modules
ERROR: No 'from' features selected. Please check options 'from_layer',
'from_where', 'from_cats'.
ADVERTENCIA: Unable to open vector map on level 2. Try to rebuild vector
topology with v.build.
ERROR: Unable to open vector map
La ejecución de '/home/pablo/.qgis2//processing/grass7_batch_job.sh' ha
terminado.
Cleaning up temporary files...
terminado.
Converting outputs
Cargando las capas resultantes
The following layers were not correctly generated.
   - Network_Distance
You can check the log messages to find more information about the execution
of the algorithm
Algunas sugerencia o un buen tutorial apto para torpes?
Gracias
Pablo
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20160924/8ff215a0/attachment-0001.html>
Más información sobre la lista de distribución QGIS-es
